Possible Boost Leak
Bytz
147
May 25, 2009
Gatineau, QC, Canada
I'm having a problem with my car (running link v3) at the moment. Idle's fine, timing's dead on, but if I hit the throttle over 3000rpm it will stall when it tries to settle back down. It also blows quite a bit of blue smoke (oil burning) out the exhaust while this happens, and I am seeing over 3 degrees of knock while in boost over 10psi.
I don't think it's a maf clamp problem because I have a vented bov because it was running perfectly on stock settings not even two weeks ago.
I checked my logs and my airflowperrev is around 0.22.
Any ideas?
SOLVED: BASE TIMING WAS OFF
Blowing blue smoke and knock under boost would come from a vented bov? My car was running fine with it two weeks ago.
Pretty much a brand new turbo, absolutely no shaft play as well.. checked it.
I did a boost leak test and found out my BISS was allowing air through. I fixed it but I'm still getting the same symptoms.
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
