Boost Leak?
Piranha451
159
Jul 31, 2003
Westchestertonf, Florida
I live in Florida and own a '97 Eclipse GS-T that is stock except for a K&N FIPK, Blitz BOV and a cat-back exhaust. The issue I am experiencing is that whenever it’s very hot out and I am accelerating at WOT, it seems that the BOV starts emitting a constant "honk" sound. If I continue to accelerate, the engine will start stumbling until I let off the throttle or shift gears. I tried tightening the spring adjustment of the BOV, but that only helped a little. Has anyone else experienced this same situation with the same BOV or another brand? Could it be boost leak? Any information will be appreciated.
Thanks in advance!
Thanks in advance!
First of all stay out of the boost in very hot weather. Get colder Sparkplugs. NGK Bpr7es and gap them to .28 MOst likely boost leak. But change the Plugs first.
It's possibe that it's a boost leak. The honk could be the air pushing past the BOV(leaking). It's also possible that it's something else.
The best way to find out if your BOV is leaking is to do a boost leak test.
Slowly turn up the pressure while you put your hand over the BOV port.
You will feel it when it starts leaking. Watching the guage will also let you know at what PSI it starts leaking at.
Plus you can find and eliminate all other boost leaks you have.
Don't forget to spray everything with soapy water so you can see the leaks
Good luck
You venting?
This happened to me when I was forced to vent for awhile, the BOV was opening a little and letting some air out, recirculating fixed it for me :thumb:
I found the problem that was causing everything....
A very loose clamp on the intercooler's inlet hose :(
I started hearing a whooshing noise after I put on the by pass valve which made me investigate harder. I tightened it up real good, no whooshing, put on the BOV and no more honking! w00t!
Piranha451 said:
How would I go about resetting the 'check engine' light? I could not locate a button under the dash. N E info will be appreciated.
Thanks!
Disconnect the battery, but if the problem is still there it will just come back on.
I have been driving around with mine on for 2+ years now, you get used to it :thumb:
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
