Porting question
always_broken
468
Nov 14, 2006
werx, Utah
Hey,
I have a 14b I plan on installing. I've read about porting to 7cm but is porting 02 housing and manifold mandatory if I port the 14b? If it is I guess I'll leave everything unported till I have access to a die grinder, but let me know.
Thanks for the quick respone, I was worried about turbulence issues. Like installing a 1g tb onto the unported 2g intake manifold.
This is a good question and one I had when I was in you're situation. If you have the opportunity to port your turbo, o2 housing and manifold you should.
Heres an Idea of the difference between a stock manifold and turbo housing size and a 7cm^2 gasket.
Silver is the 7cm^2
If you are going to port anything just make sure you match the flow up. ie. match the sizes of everything. Dont port the exhaust manifold and leave the turbo stock as it will cause turbulence and hurt performance.
If you cant port anything now don't worry. ideally would would match it all at the same time.
Ok ok, so If I do decide to dremel the turbo inlet I'll be good leaving the manifold alone? That's what I'm trying to pinpoint. Because if not then there's no use porting at all until I have the right tools.
Thanks for the replies though, I'm appreciating the help.
Yes if you port the turbo you will be alright to leave the manifold alone. Although I would recommend doing it all at once.
It's not gonna hurt having the turbo ported and you might see some benefits (faster spool). You should porth the collector on the manifold as well though. You can leave the runners alond but porting the collector and the turbine housing will make a noticable difference
  • For sale 2g NOS Sebring/Avenger floor mats
    These are slightly different shape than 2G mats but very close. NOS and still in plastic wrap. I...
    • MindBlowin03
  • Wanted 2g Anyone parting out a 2G?
    Need a few bolts that I'm missing for the rebuild, subframe and crossmember specific. Anyone...
    • Mahreeoh17
  • For sale 4G63 Mitsubishi # 284K00708 tach filter
    Mitsubishi OEM tach filter. With weather pack connector. Message 702-741-6987.
  • For sale 1g NEW ETS Street Intercooler for 1G DSM ( 4” Core )
    NEW ETS Street Intercooler for 1G DSM ( 4” Core ) $475 + shipping & paypal fees* these are...
  • For sale 2g 2g power window motors. OEM
    2g RH and LH power window motors OEM, $30 each. Sold the drivers and pass set of door switches...
