420A Pls help no start after transmission swap
leo velez
May 25, 2026
Oahu, Hawaii
So I own a 99 gs car cranks I have spark 50 psi on the rail but won’t run starts on starter fluid but stall out after I have switched the asd, crankshaft sensor car ran 3 months ago but after a transmission swap it won’t start
Sounds like the injectors arent firing. I’m not too familiar with the 420a but I’d be checking all plugs you removed while doing the transmissions swap.
My buddy is the one that swapped the transmission he said all plugs are good
Also check firing order. I know its a no brainer, but sometimes the smallest thing is the culprit. Make sure you ARE GETTING SPARK. Good grounds to the engine are super important too. Just tips.
If your is automatic follow negative battery cable to the starter there should a ground washer 14mm bolt attaches to the bellhousing could be same for the manual transmission too..
But also I would change fuel filter too, clogged dirty fuel filter will hard starting issues too
Will definitely give this I try
Also check firing order. I know it’s a no brainer, but sometimes the smallest thing is the culprit. Make sure you ARE GETTING SPARK. Good grounds to the engine are super important too. Just tips.
I am getting spark it’s the injector plug that reads low Volts
Do you have a spare injector pack.??
IIRC, that plug can be interchanged with one other. Make sure it is the correct one. 🤞
