PLEASE HELP! noise problems!
mr gordijev
Jan 23, 2005
Sacramento, California
Hi guys, I am new to this site, and figured it would be a good place to come GET HELP. My mitsubishi eclipse GS-T has 69,550 miles on it, and there is an annoying squeaking coming from either the suspension of my car or the shocks or SOMETHING. I replaced the struts and had the bushing lubed up and it STILL makes this noise. The noise happens when i go over bumps, and things like that. My friends friend said it could either be the suspension of my car since it is lowered 2 inches or the shocks i have since there stock. So any input on why my eclipse is making this noise, will be greatly appreciated. This noise is ANNOYING as heck. Thanks in advance.
-Mike
This sounds like what happen on my car. It was a ball joint so the entire conrol arm had to be replaced. I also believe that it was a factory recall.
is it from the front or back? definately check about the recall but those were the front ball joints i believe and if the squeaking is from the back then its not the recall obviously. but a commond problem ive heard of is the rear struts just gettin old and need to be replaced. do you have subs or anything in the back?
