Engine noise please help
Nosroxs
150
Apr 16, 2011
St. Louis, Michigan
2g 96 eagle talon tsi 4g63t fwd, 180,000 miles. 14b turbo swap, hard inter cooler piping and tubular header, other then that engine is stock..
Can you guys help with this? I am about to start throwing shit seriously damn dsm's LOL, is my engine toast ?? here is a sound clip recorded off my phone that was sitting right in front of the head right above the manifold.
Memo_1.mp3
I have noticed a little loss of power since i started hearing this knocking noise but not enough to were the car doesn't run right., so i thought it was my 14b turbo i just installed; so i pulled the intake pipe and checked my turbo for shaft play, absolutely none. So i got under the hood with car running and revved it up through the throttle body and this is what i hear coming from the engine. Please help, i am lost and don't know if i should go looking for a new head or a new engine..
I dont mind having to pull the engine but would you think the engine would be rebuildable or should i find another?
Stop trying to guess and go diagnose the problem. No way of knowing until you do. Best case scenario: the balance shaft(s) worn, remove them and move on. Worst case, a spun rod bearing, which means the crank/rod will need repaired/replaced; or a main bearing is worn, but rarely does that happen.
OK guys, i got the oil pan off and got up in there with a light and camera and decided to whip a wrench LOL.. check out this video and give me any advise you guys can give me please... on a budget, trying to get this fixed as cheap as possible any insight would be appreciated.. oh and i am not trying to disassemble and reassemble my self.. I could probably take the engine out and put it back in but that's about it..
Alright guys i know i already marked this thread as Resolved but a few of you were asking for a video of the crank with the bearing off. So here it is maybe you can shine some light on the subject and maybe help get this beautiful car back on the road so i can own some domestics.. :D Click video below..
In My Experience Rod KnockIs The Only Thing That Sounds Like That...Looks like tha crank got ate up a bit from the spun bearing...not sure on your options of replacing or being able to clean it up and put a bigger bearing on.
