2G Please help, no spark 2&3
jcr
Nov 4, 2024
yuma, Arizona
Hi, my name is Jose I'm new here and in hopes of some light at the end of tunnel LOL.
Recently I acquired a 95 Eclipse GSX
It's been parked for about 4 years. I re did the fuel pump and got it to start. Now I'm having this issue.
Cylinders 2 & 3 have no spark, I thought it was coil since they are both on the same coil but no success. Car seems to have engine work done to it, Cams, cam gears, bigger turbo. I checked compression to rule out jumped timing but all cylinders check good! I read on igniter IB1 & IB2 is ECU signal & OC1 - OC2 is pulse ground to coils.
I have power at OC1 and OC2 but no pulse. Can anyone suggest where to keep looking? Also it looks like someone added a cam sensor and it goes straight to a plug by the cams
ANY INPUT IS APPRECIATED!
i read on igniter IB1 &IB2 is ecm signal & Oc1- Oc2 is pulse ground to coils
Please refer the pic below.
Hi i have a 95 gsx with no pulsating ground at ignition control module . Im getting no spark on 2&3. What should i check for? I has a evo style 3 wire cam sensor
