help no spark 2 n 3
blake111
Jan 12, 2009
hutchinson, Kansas
Having issues LOL period
I have no spark in 2 n 3 but do n 1 n 4 and the wires on the back of the coil all have power Idk if they are supposed to I changed the cas and swaped ecus I checked the pt and I think that it is working right I changed the mpi relay.
The ecu harness was all hacked up I cut new plugs off of another car n matched colors n spiced them together so Idk Wats goin on can someone walk me through the steps I need to take the car starts but dies after twenty secs
its either your coil pack or power transistor. Double check your transistor sometimes they come loose.
Had the same problem a few year back and ended up being the p. Trasistor being loose just like 2gfwd said...
You're sure you didn't put the plug wires in wrong? They are numbered on the pack so I'd check that too, I've been dumb enough to plug them in wrong and denied to hell and back that they were wrong and went through checking everything else before swallowing my pride and seeing that I didn't put them in correctly.
