Please Help 2g Dsm Tuner
morales300zx
Oct 3, 2004
clarkston, Michigan
I have a 2g dsm car its been sitting for 9 months it had a bad 20g turbo on it i just replaced it with stock 1g turbo. we just finished the swap now keep in mind the batterys been out the entire time so i think the ecu reset it self because it did have a tune in it for the parts on it (660cc inj, 255 pump, rail, fmic, adjustable fuel reg., 3in down pipe and exhaust.) now the car will idle fine but stumbles hard with a small amount of boost and idle will creep down every now and then. car stalls with ac on and has a rubbing sort of sound near the timing belt. i will pay someone to come to the clarkston/waterford, MICHIGAN area with a dsmlink or whatever to fix the little bugs and retune it a do have apexi afsc 2 hooked up. like i said ill pay cash, case of beer, parts, whatever i need this running in good order by this weekend if possible. thanks Jerad 248-830-1867 call ANYTIME
Do a boost leak test that could very well be your problem. BOV leaking the TB leaking etc somewhere its leaking.
