Datalogger tuner help
DaOnE51T
88
Jan 17, 2004
Queens, New York
Hi, My dad and I are in the process of tuning his Talon TSI. He's running pump gas 93 octane. BTDC is set at 5. Here is his major mods:
Ported Evo III 16g
Ported 2g manifold
Ported dump o2 housing
FP MBC (set at 14psi but creeps to 20psi)
3" catback
3" intake
K&N filter
2g throttle body elbow
RRE FMIC
2.25" LICP
2.5" UICP
GM Maft 1.32version
550 RC injectors
255 walbro fuel pump
ACT 2600
Rebuilt transmission
Heres the first log:
Code:
TPS	Timing	o2	RPM	Knock
100.0%	19°	0.86V	4250	0
100.0%	20°	0.86V	4281	0
100.0%	21°	0.84V	4438	0
100.0%	18°	0.84V	4531	9
100.0%	16°	0.86V	4688	9
100.0%	15°	0.86V	4719	8
100.0%	16°	0.86V	4844	8
100.0%	16°	0.86V	5031	8
100.0%	16°	0.84V	5063	7
100.0%	17°	0.84V	5156	7
100.0%	17°	0.86V	5219	7
100.0%	18°	0.86V	5406	6
100.0%	19°	0.86V	5438	6
100.0%	20°	0.84V	5531	6
100.0%	20°	0.84V	5750	6
100.0%	21°	0.84V	5656	5
100.0%	18°	0.84V	5844	12
100.0%	20°	0.84V	5875	12
100.0%	20°	0.84V	6000	12
I can't lower the boost anymore than(14psi but creeps to 20psi). I've tried everything from running without the MBC to cutting the inner spring.
What should I do from here?
1. Should I richen the mixture with the GM maft
2. Buy a AFPR and adjust from there?
3. Should I lower the BTDC
4. Or just add some C16 and call it a day?
What data should I tune for? What should the o2, knock, and timing read? Whats the range?
THANKS
Add fuel. Timing is being pulled because of the knock. Is this a 1g?
Yeah go ahead and add fuel then and see what it does. Turn the bc up a little and see if it creeps any higher, if not go ahead and turn it up to 20 so it doesn't creep anywhere. ;)
Add fuel from there up.
Heres a log with no changes:
Code:
100.0%	25°	0.86V	3375	0
100.0%	24°	0.86V	3406	1
100.0%	25°	0.86V	3500	0
100.0%	21°	0.88V	3563	0
100.0%	23°	0.88V	3594	0
100.0%	21°	0.88V	3688	0
100.0%	21°	0.88V	3781	0
100.0%	21°	0.88V	3844	0
100.0%	21°	0.88V	3906	0
100.0%	21°	0.88V	3969	0
100.0%	21°	0.88V	4063	0
100.0%	21°	0.88V	4125	0
100.0%	22°	0.88V	4188	0
100.0%	23°	0.88V	4250	0
100.0%	25°	0.86V	4344	0
100.0%	25°	0.86V	4406	0
100.0%	24°	0.86V	4531	0
100.0%	24°	0.86V	4594	0
100.0%	24°	0.86V	4688	0
100.0%	24°	0.86V	4750	0
100.0%	23°	0.86V	4875	0
100.0%	23°	0.86V	4969	0
100.0%	22°	0.86V	5094	0
100.0%	22°	0.86V	5156	0
100.0%	21°	0.86V	5219	0
100.0%	21°	0.86V	5313	0
100.0%	21°	0.86V	5375	1
100.0%	21°	0.86V	5531	1
100.0%	21°	0.86V	5594	1
100.0%	22°	0.86V	5656	0
100.0%	23°	0.84V	5719	0
100.0%	23°	0.84V	5813	0
100.0%	24°	0.84V	5906	0
100.0%	24°	0.84V	5969	0
100.0%	24°	0.84V	6031	0
100.0%	24°	0.84V	6094	0
100.0%	23°	0.84V	6250	0
100.0%	21°	0.84V	6375	0
100.0%	21°	0.84V	6438	0
100.0%	21°	0.84V	6469	0
100.0%	20°	0.84V	6594	0
100.0%	20°	0.84V	6563	0
100.0%	20°	0.84V	6719	0
100.0%	20°	0.86V	6781	0
Im confused now, Is it cause its the first pass? HELP, THANKS
