dsm link question! help please
njc1064
196
Apr 5, 2005
Pittsburgh, Pennsylvania
ok, my question is about hooking up my NLTS. See, i swapped the car from an a/t to a m/t. i put the manual harness into the car. I do have the clutch cut switch on the pedal assembly (or what i believe to be the clutch cut switch). I dont need to push in the pedal to start my car. will this affect my ability to hook up this feature or should i be able to hook it up with no problems
You should be using the top (cruise control) switch for NLTS with DSMlink (TMO used to use hte lower switch for everything), which has nothing to do with the lower start safety switch. If for some reason this is missing or you can't or don't want to use it, you can use the lower switch, but you will have to have it plugged in. If you still want to be able to start the car without the clutch like most poeple, you'll have to cut the wire going up into the harness. What I did was put a switch on that line so I can disable the start safety switch normally, then re-enable it at the track to pass tech and conform to thier safety rules. Then I switch it back when I leave.
