first idle with link please help
M1L3S
132
Apr 1, 2012
maple grove, Minnesota
first idle with one rev, please give pointers.
im a noob and reading forums and a book on this stuff. I have stock injectors in right now just so I can get a grasp on this stuff.
You didn't read the two links I posted for you in the other thread. Do so as it'll help you get your idle dialed in. I'm pretty sure your stock injectors don't need 450 usec of global deadtime and your MAF Comp sliders have not been touched.
http://www.dsmtuners.com/forums/ecmlink-tuning-log-file-advice/444831-list-values-log.html
http://www.dsmtuners.com/forums/ecm...efore-you-ask-ecmlink-dsmlink-log-advice.html
Have you checked your DTC codes? You have two of them.
What are you using the EGR solenoid for that you have it activated?
Honestly I havr no idea what im doing. Im literally a child dropped into a foreign country with this situation. Thank you for not yelling or being disrespectful and actually giving advice.
This is why we have the above guides. In there, it should walk you through the basics, give you some helpful links, etc. If you find something that is not as clear as it could be, let us know so we can update/enhance it.
After reading through everything, you should be able to post up an idle log that's pretty well dialed in.
    • Sdcryan1
