piston/wall damage
ivan300
59
Jun 4, 2006
none, BC, Canada
well i blew a head gasket so i popped off the head to find out the cyl 2 piston and wall are slightly damaged, this is a rebuilt engine with je pistons, less than 5k miles on it. The exhaust valves were black on this cylinder and white on all the rest. what could have have caused this.
what should i do?
Looks like you had a detonantion issue on that cylinder, better check the rest of them while its apart.
Looks like it got real hot in there. Are you sure this engine has only 5000 miles on it. I cant see any signs of a cross hatch. What was the cylinder to piston clearance when you fitted the pistons?
melted the pistons, stock 2gnt ignition is too advanced and the knock sensor didn't do anything.
which is very weird cause even motors with high miles still leave the honing marks.
It would have been a good idea to upgrade the valves and the retainers. With a new bottom end why risk it, you already spent the money a little more wont hurt. Depending on the motor milage the valves and or retainers for that cylinder could have been sticking or if the cam had a low side it could have been holding in the pressure and never releasing it causing the cylinder to detonate. The pressure has to go somewhere.
