Piston wall clearance
How much power do you plan to make? Clearance would be different from 200hp to 400hp.
What excatly are you trying to do?
If you do not have the tools to measure with, how do you plan to figure the PTW?
I seriously though that the manufacturer would have a recommended sepc for them, goals are 300hp, i'm actually on vacation just came to my mind about the PTW for my pistons, (rebuilding motor), thought it was a standard measurement i can right down and remember
PTW is cut into the piston from the factory.
This tells you.... ^^^^^^^^
So I can walk you thu the math, we will use an engine that has a STD bore of 85mm or 3.346
Now add the .5mm or .020 for the over size.
The target finished bore should be 3.366
Now when you mic the pistons, you will see that they are smaller, appox 3.363 to 3.3625
That works out to be .003-.0035 of PTW
