Ross piston to wall clearance
Heartless
99
Jan 18, 2007
MTV, Ohio
Ok, I'm going to run a Ross/Eagle combo in my 6bolt, BC 272's, Holset HX35 with 23psi on street and up to 30psi at the track. Ross' spec's say .006 piston to wall clearance but that seems a little bit much to me, I was wondering if anyone that is making around 500awhp has any suggestions for a piston to wall clearance or if the .006 will be adequite? Also would you happen to have a ring end gap suggestion or is the stock spec's as suggested by Ross acceptable?
Thanks
No they're not coated, I went with the .0055 clearance, .020 for the top rings and .023 for the secondary rings, I appreciate the help, thanks!
