piston ring size
sharky559
191
Mar 6, 2010
Sanger, California
ok so i need to change my piston rings. to find out what kind of rings i need do i have to find out the diameter of the bore and the piston. and subtract the bore size from the piston size. could someone help with this.:hmm:
You're thinking of another measurement, piston to wall clearance. Off the top of my head I think that clearance should be around .0012 to .0020. You'll need an inside and outside micrometer to measure that.
ok so i so i got some numbers. The piston is 85.00 mm and my bore is 84.50 mm. Dont know tho any help
Well that's impossible, but it sounds like you have a standard 85mm bore... so get standard rings.
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 1g 1990 Turbo Throttle Body ( rebuilt )
    1990 Turbo Throttle Body $85 shipping & paypal fees* this throttle has been rebuilt and is in...
