spyderdrifter
- 5,434
- 864
- Jul 11, 2009
Somewhere in,
Colorado
So I have a '95 GST with a 6-bolt swap with 2G head. I just did a compression test today and have severly low PSI across all cylinders. So this weekend I'm gonna check the piston rings and the valves. If it's my piston rings, I'm considering just upgrading the pistons and possibly jusy doing a 2.3 stroker or the 2.4 if I can find it again. I would like to know what is the best running size I can bore the block to and which psitons would go best with it. Thanks.
