Pintle cap fell in injector hole
Try to use a shop vac to suck it out maybe thru the throttle body.
Take the spark plug out of the cylinder of the injector, duct tape in a vinyl tube into the end of the shop vac and lower it down, get a somewhat flexible line so you can kind of rotate it to sweep the entire cylinder wall.
It would help to empty out the shop vac before hand so you can make sure that you got it out.
in gonna go try that now. ill be back
If you think you got it in the vac just turn it off and open the vac up and look. Also unless the valve is open it won't be in the cylinder. I would say its in the intake runner or near the top of the valve.
I think you should have just sucked alittle longer with the vac... i once knew a girl who could fix that for you.
looks like its time to just get in there n take if off..
if you never did one before take lots of pictures
before i started taking it off i tried a longer hose and i still came up with nothing, but you should send her my way! :sneaky: and taking this manifold is no easy task....how in the world do i get the bottom bolts out??
You can get your arm under the intake manifold on the timing belt side I stick my whole arm down then start wrenching
