Pictues of OFH
sypherzero
461
7
Feb 14, 2008
Marion, North Carolina
Hey guys, I'm trying to see what your OFH setups look like. Is it possible to run the oil pressure sender, factory dummy light, turbo oil feed, and an aftermarket oil pressure gauge? If not, what would you guys recommend running off of the OFH? I'm going to be using an Evo III OFH, and I know about the one port you can tap with 1/8" BSP already, and I plan on utilizing that for the factory oil pressure gauge sender. Pictures would be greatly appreciated, thanks!
No Pictures here, But I replaced the Stock Oil Pressure Gauge Sending Unit with the Autometer Electric Oil Pressure Sending unit.
There just wasn't enough open spaces.
1990 Only Oil Filter Housing w/ Air Oil Cooler BTW
    • george bromwell
    • pma1123
    • Sdcryan1
