OFH Porting
YoYo_4G63
187
4
Sep 5, 2008
Carolina, Puerto Rico
Porting the hole of the ofh, i think i've went to far down :(
So i'll be ok leaving it like that or i mess up the ofh?
Typically it is the other end that you need to worry about. All that work done near the gasket surface will do practically nothing.
The oil pressure relief valve is a simple spring loaded piston. To reduce the pressure build up, you want the relief valve to do its job quicker than an original setup. The area away from the gasket surface determines the pressure because the piston will need to retract different amounts to allow oil through depending on how the housing has (or has not) been ported. This is why members in the thread you linked to keep showing the bell or D-shaped opening as ideal. Effectively, that increases the cross-sectional area at the point where fluid will flow first allowing the system to regulate the pressure a little better. I suppose it would depend on the high pressure characteristics of your car, but that seems to be the most common approach.
