OFH Feed
lucid15
527
Oct 10, 2008
Portland, Oregon
So i am feeding my Evo 3 16g from the OFH, i got the kit from extreme PSI do i need a restrictor at all or am i fine?
If you have removed your balance shafts you would need a restrictor if it causes excessive oil pressure. For waranty purposes I would let your vendor recomend a restrictor size if this is the case.
Do you still have your balance shafts? I used to have a 16g fed from the oil filter housing with the FP install kit. I didn't have any problems with it and extreme psi would most likely tell you to feed it from the OFH. I am now going to install another 16g on my new gst with balance shafts removed and being fed from the OFH. I bought the FP install kit again and I ported my OFH relieve hole so I am hoping I will be ok without a restrictor. I still have to call them though and see what they have to say about it. I'm sure JUSMX could answer your question, he's a turbo expert. Just shoot him a pm.
