Derrack
- 49
- 1
- Nov 5, 2009
juneau,
Alaska
I'm an optomist. Looking for worst case scenario for my problem.
Driving down road. loss of power. pull over. hear oil boiling. oil level fine. hmm i think to myself. coolant overflow empty. shiat i think to myself. put water in the empty colant system. drains out of a blown hose above the oil filter that feeds the oil colling system. i think to myself new hose. go get new hose and swap it out. fill with antifreeze diluted. two gallons down... 3 and a half not thinking tomuch since its pitch black out and am spilling... 3 gallons ?*#!. look under car found an exaust leek comming from under the passanger seat... because of the antifreeze coming out.
so i would think blown headgasket.. its obvious the car overheated. so what are the chances of warped/cracked head and other problems i should look for. i know the turbo must have gotten that oil hot add the engine so whats some damages i should look out for and check caused by this happening?
The rubber from the filter on the valve cover vent got reall droopy..
go pessimists go!
thanks for the input.
go pessimists go!
