Performance tricks.
turboguy_16g
Apr 8, 2011
phoenix, Arizona
Im trying to figure out little trick to give me more performance out of my 6 bolt 4g. For example what should or can I use from a 2nd gen for my 1st gen. Any little tricks of the trade will help, or some advice.
Thanks.
About the only thing from a 2g that would give any benifit would be the mas and the trannys are a little better.
Running e85 entails more than just putting it in the tank. My car on stock everything, except fuel injectors, pump, and eprom chip trapped over 105 consistantly on e85.
Thats not stock everything! :p
Just kidding. Thats pretty sweet. Low 13 1/4 mile times?
The way you put it made it sound like the OP could just fix any oil leaks, do a compression test, boost leak test, change his belts and then dump in e85 LOL... Didnt want to steer him in the wrong direction and have to answer to his new "Why is my car running like this" thread next weekend :p
