pedal assembly?
BlackStar
Feb 5, 2006
Colorado Springs, Colorado
i just got my 90 tsi awd up and running and now i got a clutch problem. the pedal has tons of slop, but if i hold the pedal half way pushed in (till it has pressure) the clutch will engage. Also sometimes when i push the pedal in the engine surges and makes a slight grinding noise. If i take my foot all the way of the pedal (while driving) i lose almost all pressure in the pedal. Any help is appreciated.. thanks
ok well is a better idea to get a new clutch pedal assembly or to have the one that I have welded up?
Sometimes welding can melt the plastic bushing thats inside the pedal if its not done correctly. Shep sells brass bushings for the pedal assembly. He also sells new assemblies. Its on his website.
Back in the day, before anyone made the brass bushings, I fabricated my own using bushings that ALMOST fit, so I modified the assembly and the bushings to accept it. It made a WORLD of difference in my clutch pedal.
If the lever is worn, I would replace it and install the brass bushings. :rocks:
Ok so the story gets deeper...... i figured i would try and bleed the clutch before i took the pedal assembly and all that out ### I figured Id try something easy first, but when we bled it the first time the pedal stuck to the floor and now the clutch is not engaging at all!! The piston on the slave cylinder will not push backout until you physically push it out... could this be my problem? Oh also I have just about all fluid coming out of the bleeder not much air..
I agree.
I really hope that its a hydraulic system problem for your sake. I re built my pedal assy once in my 90 FWD and my god....hands down the worst thing ive ever had to do to a DSM in a decade. I rue the day i ever have to do that again. Sorry, im sure it doesnt make you feel too good about it, i just think you deserve a fair warning haha. My fingers are crossed for you! :pray:
ok well should you have to push the little piston on the slave cylinder back out or should it pop out and push the pedal back out?
I'd be sure the pedal assembly is in good shape before going any further.
Very simple, go under the dash, locate where the rod for the clutch master attaches to the pedal. It will be above the gas pedal. Next push the pedal down with your hand and watch the rod on the master. It should move at the exact moment that you push the pedal, if it doesn't its bad
Clutch Pedeal Adjustment - Team Rip Engineering
After having done about 4-5 of them, it is one of the worst things you will ever have to do on the dsm.
Im not sure im understanding what youre asking.
If youre asking if it should return to the depressed position on its own, yes, and that in turn will push the pedal back out.
UPDATE!!!!
So i changed my slave cylinder a couple days ago and the clutch worked ok (ish) for about half way around the block and then it seemed like I lost pressure for the pedal. since then it has gotten worse to the point where it doesnt really engage and i cant get it in any gear!. Also when i push the pedal in it makes a spinning grinding sound right where the motor and tranny bolt up.. I think Im at the point where im gonna tear the motor and tranny apart and see whats going on.....Unless anybodies got any ideas??? Thanks guys!
  • For sale 4G63 Frontline Fabrication V2 Billet Valve Cover
    Frontline Fabrication V2 Billet Valve Cover $750 + shipping & paypal fees* swivel AN fittings...
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
