PCV valve
MistyShower
Jun 11, 2012
goodyear, Arizona
So when I bought this car there was no PCV valve on the valve cover so I ordered one online. The thing is, is that its not wide enough to even touch the threads. The part number is 045-0247 by Beck Arnley. I just want to know what PCV valve to get because I am having no luck :cry:
Thanks! and tbh im not sure :confused: it looks like this
okay, and whats up with my valve cover? ive never seen one with those purple knobs or any knobs at all.. I know that the wire cover is from injen but thats about it.. ( just bought car)
You should get another non modified valve cover if you want to run a pcv. Your valve cover has been modified with an fittings for a catch can setup it looks like the original holes for the pcv and the line to the intake have been filled in and new fittings welded on. The pcv is supposed to go on the back of the valve cover by where it says "16 Valve". It would probably be easier find another valve cover than to make that work.
