- Thread starter
- #26
dnhieu
- 1,927
- 17
- Aug 16, 2004
panama city,
Florida
you should take some pictures of that....
dnhieu said:also this guys post ^^^^ is completly right about the air naturally comming out. i put my finger over the top (where the filter would go on the catch can) and it had a bunch of pressure behind it. this was when i boost leak tested it and while the car was at idle....
MyBeatGSX said:EDIT: My bad on the guy I quoted. I just disagreed with you and then agreed with you half way down. I thought you meant it wouldn't suck anything out.
project_tsi said:Hey all, here's how I have mine setup. I drilled out the pcv hole with a 11/32" bit and tapped it with and 1/8" NPT tap. I also did this again by the ex. cam. I then used 2 1/8" NPT to -6an adapters and screwed on a 90* -6an pushlock fitting in the PCV spot, and I used a straight fitting by the cam. There is another stock breather in the middle of the VC that I just hooked a hose too b/c its already hollow. The trick is to drill your extra holes above the VC baffling so no extra oil is lost. I'll be honest, I'm not even running a catch can right now, I just have hoses dumping close to the ground, but the amount of oil it drops out is very minimal. I check oil levels multiple times daily, and I've never once had to put oil in. I will eventually run a catch can but I'm to cheap to buy one right now.
Yes, for now they dump to the ground, they dump about 2 inches below the crossmember. There is absolutley nothing dirty in the engine bay, no oil coatings, etc. I'm not sure what type of catch can I will run. If I buy one, I'll have to add another fitting b/c most only come with 2 inlets. I may end up making one out of PVC piping. and paint it black and hide it. Cheap and easy. The extra fitting is just for extra ventalation.No_Skillz said:That's interesting... where do all the lines go? Just dumped to the ground? If so do you plan to run a catchcan soon and what type? What was the point of the extra fitting by the exhaust cams?
2blue4uRS said:Is there a way to pull the crankcase pressure without rerouting it back through the intake.
Or you could just buy a cheap $2.00 1/8 NT fitting, instead of taking the time to modify the PCV valve.MILITISINVICTUS said:Gut the PCV valve by drilling it out. Re-install.
The big question for me is:MILITISINVICTUS said:Outcome:
Now you have nice negative pressure from your turbo making it easier for positive pressure to escape the crankcase. The filters keep the IC pipes clean. Maybe you even get a bit of that reduced resistance for the underside of the pistons that some folks try to achieve.
Yup. Old V8ers, hotrodders and drag racers have been using this type of Evac. system for a long time.sbiggi said:Yes, get a steel brake line, slash cut it,.
Weld the slash cut into the exhaust after the cat with the cut facing back.
put a oneway valve similar to the pcv valve inline.
Under full load it will some pretty good vacumm.
It's not as bad as you may think. I've been running it like that for about 14 months, and the coating only extends to a 12" radius from the breather top.No_Skillz said:I don't think there's going to be a big problem. You'll just have a nasty coating in your engine bay after a while with that setup.
99gst_racer said:Or you could just buy a cheap $2.00 1/8 NT fitting, instead of taking the time to modify the PCV valve.![]()
Well, we could get technical and add in the costs of mileage to the store, plus your time consumed in the process, plus the pain and suffering of being away from your tools, and come up with more than two bucks. I charge double OT for wandering through aisles, and standing in lines near whining kids..
Anyway, you're talking to someone with a boost gauge mounted in a pringles can, so the "did it because I could" factor is operant here.
How important is it to have negative pressure pulling on the crankcase pressure?
I don't know. I figure it falls between the latest news on Britney, and world peace. Roughly.
Obviously it will help, but can the crankcase release pressure adequately without a negative pressure source?
That depends upon the definition of "adequately".. if you have some slight ring blow-by, maybe it's a nice-to-have. Will never be a must-have, but as you say, it will obviously help a bit.
dnhieu said:I dont understand how myset up isnt efficent like stock. i could be drawing a little less air under vacumme granted the intake isnt going to draw -15-18 vacumme but i got more ports for air to come out to make up for that. plus all air is accounted for so when i go get dsm link i wont be missing any amout of air if i dont have any boost/vacumme leaks.
someone mentioned it is point less to connnect to the intake, but he also agreed with me by saying that the port on the side of the intake will draw vacumme. well with the vacumme line connected to the intake im drawing vacumme like the pcv valve would be doing under vacumme. under boost conditions ill be letting out all the air in the valve cover. to me it seems fully functional plus i wont have oil in my intercooler piping and eliminated another boost leak spot.
MyBeatGSX said:The problem with your setup is that there is no point for air to ENTER the crankcase. You're drawing the air out and have nothing to replace it with, so you'll get rediculous vacuum and start pulling air past your rings and other seals. I doubt that would actually happen, but that's the basic idea. Its not really vented unless there's a place for fresh air to get in.
underradar92 said:You aren't likely to EVER have too much vacuum in the crankcase, case in point, Angelle Seeling's (now Savoie) P/S bike had at one point three electric vacuum pumps, 'till NHRA rules prohibited that many, so her team just used larger ones& thats on a 1500cc engine for only 7 seconds!
MyBeatGSX said:Think of it this way. Hook a vacuum pump up to an empty soda can. What happens after all the air comes out? The can colapses, what happens after that? Leave it hooked up long enough and you'll blow a hole in the side of it to let air in. Obviously that's an exaggeration, but you can't keep sucking air out of something without having somewhere that something to replace it can get in.
1stGenRocks said:your missing the point. Your never going to get enough vac to cause a problem but you will get all the blowby gases out. And as a added benefit you never have to worry about the pcv valve leakign under boost again.
Your soda can example isn't quite right. You forgot about the blowby from the rings. Even in a good engine there will always be some blowby. As long as you get the blowby drawn out you dont need fresh air. The closer to vacuum the crankcase is the less friction on the rotating assembly and the better the rings will seal.
Theorieticaly you need to let air in to get air out but the goal is to get as close to vacuum as possible.
Even on a proper functioning stock setup the intake hose becomes a vent under boost. While your boosting the pcv valve is shut and your getting the most bloyby so the pressure goes out the intake hose and oil coats everything.
