PCV Valve
ZiggysDSM
789
4
Jul 25, 2004
Bel Air, Maryland
Ive looked and looked for a pcv valve with -6an fittings on it but I am unsuccessful. Does anyone know if they even exist? i have a one way check valve on the intake side but i lack the pcv valve on the valve cover. Can i use another one way check valve for the pcv valve also?
Since you have a nice usable check valve on the intake side you can just go to the auto parts store for a PCV valve since you don't have to worry about it leaking under boost anymore. The pcv valve hole is measured and should still be used.
The pcv valve hole is welded shut and a -6an bung is welded in on top of the manifold in its place going to the rear catch can.
