dnhieu
- 1,927
- 17
- Aug 16, 2004
panama city,
Florida
alright yesterday i did a boost leak test and it appears my pcv valve is bad. i did alot of research and i came up with two choices. i can 1. remove it or 2. keep it. well if i keep it 99.99999999% of the crap you buy at the auto parts store is going to allow air past it under boost. well under further research i found that only 9-10 pcv valves from the STEALER ship work.
so i think im going to remove it. okay this is the idea i have. im going to make my own oil catch can with 3 nipples on it and no filter on top. im going to route all comming out from the valve cover to the oil catch can. then run a third on to the oil catch can to the air intake.
the question i have is there going to be a problem from always drawing air out of the air valve cover? here is a picture i made, please excuse my drawing. i am no expert by any means...
thanks in advance
david
thanks in advance
david
that shows that there is pressure in the crankcase (sometimes, and on some cars) to be able to need to vent itself or a pressure gradient as you called it. now not every car is the same but the way he has it set up if there is any pressure in the crankcase it can vent itself. if there isnt any pressure then there would be no need for the system in the first place and everyone could just run without a PCV.
i get what you guys are saying. its just i guess different strokes for different folks.
