Spoolin98
- 1,646
- 24
- Feb 1, 2004
Easton,
Pennsylvania
Im looking to switch over to SD and Im running out of boost sources on the 1g intake manifold.
Im already T'd off the BOV for my MBC, which I know is not preferred.
And Im T'd off the FPR for my boost gauge. I dont want to T off anything else for manifold pressure for the MAP.
I know that I could pull the manifold off and drill and tap it for boost sources but Im trying to do this without removing the IM if possible.
There is a galley on the 1g manifold that is right above the EGR and it runs the entire width of the manifold. There are plugs on either end of the galley.
I removed the plug above the EGR and installed a barb fitting for a boost/vacuum source. Im just not sure if this is going to work and wanted to see if anyone else has done this?
The picture of the runners shows how the galley gets the pressure, there are tiny holes in each runner. This galley feeds the PCV valve boost and vacuum but it looks like its designed to minimize boost and maximize vacuum. Otherwise I think Mitsubishi would have fed the PCV the same way they fed the BOV and FPR right off the main plenum.
What do you guys think? Can I use this as a boost source for my MAP?
Oh and the pictures are of a spare intake manifold I had laying around.
