Palm IIIxe good enough for logger?
2DaTrakNow
265
7
Dec 20, 2005
hillsdale, Michigan
I have a Palm IIIxe from a few years ago, and i was wondering if this would be good enough to get a logging program? Also, what program should i get?
I'm not an expert on palms, but I use an M100. Which i'm pretty sure is really old, so your IIIxe should probably work fine. I used MMCD software, but keep in mind that im also a 1G.
I use a PalmIIIxe in my car and it works fine. It isnt a fancy colored unit but it does the trick and is cheap.
I also use MMCd for my 1g but I dont think it works for OBDII. I know pocketlogger does work for your car though.
That palm is perfect, identical to the palm IIIc, minus the color. All you need is the pocketlogger setup.
www.pocketlogger.com
oh and maybe a sync cable unless you dont mind having that bulky cradle in your car somewhere.
