2G P1103 code.
xXHigh BoostXx
Feb 24, 2017
North port, Florida
What would cause p1103? BCS is plugged in but im using mbc. Have a piece of vac line from top port to bottom port of BCS to block it off. Mbc holds@ 25~ Just fine so wastegate is working.
When the light came on I was not even under boost. This is the second time I got p1103 last time I checked everything out and cleared it. Its been a week or two and its back.
Searched and came up with mostly stock turbo owners hitting fuel cut but I dont have that issue.
No. But as stated its not plumbed into the turbo so it sees no boost.
Will look into replacing it though.
