Airsign89
- 178
- 5
- Jul 4, 2011
troy,
Michigan
Hello all:
So this may be a long thread, so those that have short attention spans, please skip. I got my car ready for winter a month and a half ago and then the weather in michigan didn't turn, ie no snow and the such, so I ran the car every week or so and about three weeks ago the idle got somewhat erratic and a ISC code came up, thus I changed the ISC, it seemed to fix the problem but I don't daily drive it, so issues aren't as pronounced. Two days ago I went to Ann Arbor, MI to pick up some parts and on my way home I merged onto the highway and hit the gas about 100% through part of second gear and part of third gear and when I shifted to fourth the car fell completely on its face: the exhaust sounded as if only three cylinders were firing(It sounded like my second 420a engine before the rod bolt broke and a rod went through the block, yes, a mess); power was non-existent(although I was only at about 10% throttle position), and so I limped about a quarter mile to the next exit and parked it.
As an aside I recently lent another dsm'r my logger and wideband because I thought I had no use for them for a bit.
So I start to go through all of the electrical plugs in the engine bay: CAS(cam angle sensor); ignitor coil; plug wires and every other electrical plug that is reachable within the engine bay and checked the oil dipstick several times to see if I saw any bits of metal in it, and after the car had cooled for an hour I checked to see if I saw any traces of oil in the coolant...nothing. I seriously thought I had melted or bent some exhaust valves(I never smelled gas from the exhaust at idle or otherwise, though.)
So after an hour I felt brave enough to start the car and it immediately started and idled pretty much like it had when I bought it, so I began my trek home and when I got off I75 at 9 mile I remembered I didn't have my logger, so I stopped at the murray's/oreilly's and used their scanner which revealed a....P03000 code!
I limped it to my house and yesterday did most of what everyone says to do-for cheap-when you get this code:I did a boost leak test and found a major leak near the throttle body(when I did the ISC), so I pulled the entire assembly and seeing as the gaskets were metal, I added rtv black in a thin line on both gaskets and tightened them to spec. I had ngk br7's from last summer when I was running more boost, so put those in; I checked the plug wire ends and they seemed fine, I checked all the fluids and anything that would seem mandatory for the problem and reset the computer and the car has run...fine, for a the last day or so.
My questions are: When does the random misfire code usually show up: full throttle; half throttle or just anytime the problem is present? Also, is it a bad idea to give the car full throttle? Will the problem show up via a blown block? I have about 50 miles on it and am waiting for the code to throw again.
Thank you guys very much,
Matt
Matt
