Resolved 1G MPI fuse blows out every time I put one in
rza808
81
Feb 14, 2010
Makakilo, Hawaii
I know there is old post for this but i have a new question, my fuse is blowing every time I put a new one in and turn the car to the on position. I have blown 13 fuses trying different things but I cant figure it out.
When I check the MPI male connectors to the ground one has 12volt the other 0 but when I touch the male connector closest to the bumper side to the positive of the battery I hear a buzzing sound.
Please help thank you. I will do step by step as you post and tell you results
Never mind I figured it out, the O2 sensor wire on engine side of plug grounding out on block. Black tape, problem solved :thumb:
Good job. Now find the "thread tools" link above your first post and select resolved. :thumb:
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
