Oxygen Sensor
cxx
86
3
Jan 1, 2003
Berlin, Europe
My oxygen sensor is broken. Will the sensor of a 1G N/T work in my 1990 Plymouth Laser RS? If not, where is the difference between a N/T and a Turbo oxygen sensor?
Thanks...
If you're pulling the sensor from a 1.8, then it won't work. 2.0 engines (turbo and n/t) are four lead connectors, where two of the leads are for a heater element inside to warm up the 02 sensor during cold starts. 1.8 02 sensors don't have that heater element.
As long as you get your 02 sensor from a 2.0 engine, you should be fine.
