our transmissions
Yeah, if you want to stay in each gear longer, just turn the boost down to 10psi :) then you'll be just like the other cars.
but seriously, the easiest way to add taller gearing is to use a bigger tire. EVO3 has a taller first gear, second gear is the same, and 3rd+4th are actually shorter.
