- Thread starter
- #26
turboglenn
- 6,375
- 124
- Nov 5, 2007
RIpley,
West Virginia
well, i spoke with Darren at FFWD the other day about this and some other things i was wondering (using the shims from his cams with 3g lifters) And he basially said if you can get the the pressure dropped to the turbo using a restrcitor that's all you need and that if you can keep it under 100psi you're fine.
Somehow i still want less pressure even with the added relief valve in my head, but just changing the battery today and pulling the fuel pump relay in -17* winds was too much. I've got something half loose in the front end that's showing up as a spike of phanton knock when i break the wheels loose on the road, so i'm hoping to get under the car and either clip the spring or add some washers to it and go from there next week when it's supposed to be in the upper 40's for temps.
Darren also said that using a thicker oil will lower pressure. I had assumed the opposite but never compared them back to back.. My machinist doesn't wanting me running anything but 5w - 30 for my warranty and darren says to use nothing less than 20w -50 so i'm torn on sticking with my warranty, but would like to see any other option for getting back reasonable pressures.
I'm sitting at 60psi at ~3200RPM cruise..i get to 80 by 4500 and then i'm in the 95 range from 5k to redline. I knwo the valve in the head is keeping the turbo safe and lifters in check, but i really would like more than a "don't worry about it" in my quest for the answer to "what can too much oil presure do to your main and rod bearings?"
) and it's still alive as well
It still pulls like a freight train though, this turbo's never felt so good in this car, especially at 15 psi ( this motor don't like 20+ on this timing curve) I think i may put about 5 gallons of e85 in tomorrow since i can flip betweeen maps on the fly and trim the fueling as needed
and still using them. If i didn't have to buy a battery yesterday i would have sprung for new plugs and just put em in, but times are tight. I'll have some loot again tomorrow so we'll see what happened with new plugs
