Ostrich bin?
JohnnyT
104
May 15, 2007
Sioux City, Iowa
I am using this page to make a bin just to start with. I will be using ds-map soon but I want something till then. What should I choose from the drop down for my dead times if I have FIC 750's? Is there a better way to make a chip than this page,which is very easy? I was also wondering what can I use to load the bin onto the ostrich, Tuner Pro? or anything else?
Thanks
The hwnd.org site has the most detail. But you'll need a hex editor and a bit of time searching through hex. If you want the extended maps, I'd use the hwnd.org instructions with winhex(free hex editor) on a bin from that website you posted with the maf hz range doubled. Then from there, use tunerpro to do all your other editing. It's free. Those bins from that site are 32K bins luckily. You will need the 32K .xdf (free definition file) for tunerpro plus the free tunerpro software. It also happens to be the definition file with the most options already setup. The common .xdf doesn't have an option to double the maf hz or extend the timing/fuel tables. It also doesn't have nlts, studderbox, octane reset, or injector pulsewidth cap removal.
Of course, you can modify the tunerpro .xdf to do all of that if you do your homework.
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
