GSTurbo1
- 610
- 1
- May 2, 2012
Pickens, SC,
South Carolina
What recommendations would you guys have for a thermostat... I was thinking about taking mine down a little bit. I think it is mostlikely the stock one still on it.
You want to keep temps between 195-205. My problem is that using the stock oem thermostat it opens just a little late and my temps start climbing to 215. Eventually the fans bring it back down to 205, but it just continues to go back and fourth. I'm going to swap it out for a 170 thermostat this weekend to see if that helps keep it a little lower, and adjust via coolant offset if its a little low. With engine temps over 215 and intake temps close to 100 degrees I'm loosing a lot of timing up top.
*edit* just realized your were running a 420a so it may not apply to you directly.
Do you know at what temp makes peak torque? Probably not, and I'll bet a lot of money no one will post data showing it's not the oem's temp. If someone can show it's other than oem temp then that's when you might change, but in the absence of that data there's little point. In absence of the data I would trust the Mitsubishi engineers optimized the selected operating temp minimum (aka the thermostat temp) to be optimum for minimal wear on the engine and peak torque. Assuming that is the case, there's a good chance lowering the operating temp will not only lower your torque but also increase engine wear for no gain. I'm basing this on my readings in engine tuning, but I too have no data to justify my recommendation beyond my general theories on engine operation and assumptions on Mitsubishi's engineering capabilities.
ok, alot of people have told me to go with the 170* im about to just order it honestly.
find which ever gets you at optimal temp. although if oem isnt keeping you there you could very well have something else goin on.
