Open wastegate vs. re-circulated
a91eagletalon
Supporting Member
278
13
Aug 24, 2005
Norfolk, Nebraska
Got a simple question I like to get your guys opinions on stuff because it helps be decide whats the best way.
Should I go with an open vented wastage or re-circulate it. I don’t think there is any performance gain either way but the open vented waste gate makes more sound and i am not sure that what I want or not what do you guys think in your opinion.
Thanks
MP
Op if you look on most vendors sites they have recirc kits most of them are using the new tial mvs or mvr waste gates and it will bolt up to the hot side of a mitsu flanged turbo other wise watch the classified for the old school slow boy manifold with the waste gate on the runner it will be a tial 2 bolt flange not the v band like mvs or mvr
stmtuned.com is a good one...you can also search ebay and on here
I was not planning on using the internal gate on the stock turbo housing because the turbo i have dose not have the gate in it was taken out and the pivot hole welded shut. So it is prenatally open now.
So i suppose the easiest way to fix that is just get a o2 housing that has a external dump with a flange welded on it and bolt the wastegate on there. Then dump it from there
20g dumped in a Spyder @ 17ish psi:
[ame=http://www.youtube.com/watch?v=ATaSn89Gtz8]Dumped 20g - YouTube[/ame]
Go with a v-band wastegate. You'll definitely be glad you did down the road
  • For sale 2g 2G AWD Rear Knuckle Set
    2G AWD Rear Knuckle Set $230 + shipping and paypal fees* these are out of 2GB so you get a...
  • For sale 2g 2G GSX/GST Front Knuckle Set
    2G GSX/GST Front Knuckle Set $150 + shipping and paypal fees* on the L side Knuckle the little...
  • Wanted Looking for an Evo 3 16g
    Anybody selling one let me know. Tried ebay and its all knock offs
    • heresjimmy42
  • For sale 1g 1990 STM shifter base bushings
    1G 1990 STM shifter base bushings.
    • drich970
  • For sale 1g 1G Radium fuel rail
    1G Radium fuel rail with built in FPR -8an feed and return
    • drich970
