Only building 12psi
Bens95TalonTSi
55
Mar 7, 2004
Tucson, Arizona
I just got a boost gauge and a turboXS MBC. I tried every thing and it's only building 12PSI. I unhooked the line from the waste gate and let it build as much as it can and it only builds 12PSI. Any ideas?
um..thats the stock boost....why you expected to hit 22
then...the reg questions..
what turbo set up do you have? what boostcontroller do you have? what wastegate do you have?
what do you have your boost controller set at?
you know the more helpfull info....:confused:
Here's some more info:
T28 turbo
TurboXS MBC
Hooked up the MBC a few different ways and it will not build more than 10-12 PSI. I run it with open wate gate and it only built 12 PSI. I'm trying to get 14psi.
Originally posted by Bens95TalonTSi
The T28 is new. I just got it from Garrett 4 weeks ago. A friend of mine is going to do a pressure test.
Profile doesn't mention having an aftermarket or 1G BOV. That's your problem. The stock 2G unit leaks @ 12PSI.
  • For sale 98 GS-T for sale
    Here is my 4g63 7bolt fully built for sale
    • Yahdin2G
  • Wanted 4G63 Mpi relay
    Looking for a 95 eclipse gst mpi relay
    • SquatchinGST
  • For sale 1g 92-94 Mitsubishi tail lights
    These were take offs from a new GST on a road race team. I had got boxes of parts leftover...
  • Wanted GVR4 3000gt vr-4 gen 1
    Looking for a 1st generation vr4, preferably 1993 due to the 25 spline output.
    • Pressterra
