Stutterbox only building 5psi?
Im almost positive all my leaks are gone, lasttime i leak tested only my TB was leaking.
Since then Ive gotten a new TB.
If i have any still its at my MBC.
Whenever ive done it ive held the stutter for probably no more than 10 seconds.
Anti-lag and a 2-step are only vaguely similar, and have very different uses. The fact that you can build boost while stuttering is not by design.
I knew they were different, anti-lag being superior , i guess i just expected more than 5lbs.
Im not dissappointed at all, launches are pretty violent...just needed to make sure im not missing something.
What is anti-lag? I 'm in the market for some type of studderbox (DSMlink, MSD DIS 2) but not sure what to get.
You again LOL
If you have the funds get dsmlink, if your el cheapo like me just get a chipped ecu.
( Think hondata ) Similarities. .... I run my stuttarbox off the chip, and I get no lift to shift
were i keep full boost and dont have to take foot off gas during shifting while not overreving.
The chip is a good comparimise. Just get a logger and wide band first before you start tuning.
http://www.dsmtuners.com/forums/showthread.php?t=230269&highlight=anti+lag
http://www.dsmtuners.com/forums/showthread.php?t=145181&highlight=anti+lag
http://www.dsmtuners.com/forums/showthread.php?t=172983&highlight=anti+lag
http://www.dsmtuners.com/forums/showthread.php?t=136425&highlight=anti+lag
