Okay, Do my Airflow numbers look right? I've searched and made me even more concerned
MarkAngelo05
201
Nov 7, 2006
Pearl City, Hawaii
Hi!
I know this is a bit of a noob question, but I would like to know your opinions on Airflow numbers...
I'm using a KEYDIVER STAGE 3 Chip/eprom ecu ZEROED OUT AFC Corrections.
Okay, well, I have a custom 18G clipped 15 degree TD05 turbine wheel stuffed in a GT PORTED housing, Ported GT manifold, tubular o2 housing, to 3 inch exhaust no cat. fuel mods and other supporting mods.
I'm set at 18-19psi of boost, and my peak airflow is only 31.15 lbs/min @ WOT 6300 RPMS... is that about right?
I have checked for boost leaks, etc.. but I thought It should be less... or more... that's why I posted this... I started experiencing knock at 6.3k rpms so I let off there.. I'm just trying to get things squared away before I get on the dyno.....
Thanks!
Mark
If you are using an AFC to tune the car, then your airlfow numbers will not be correct as they basically "hide" airflow to lean the fuel curve out.
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
    • ist dwa
  • Wanted ISO Extreme Psi weighted shift knob
    Easy peazy…
    • James92
  • For sale 1g 91-94 ignition coil
    1g coil with harness side igniter harness. Digging in a box of remains from a yard six bolt for...
