Oil pump shaft seal drain
babyviper
607
150
Feb 12, 2003
Mays Landing, New Jersey
In the past, I've had issues with getting RTV in the oil pump shaft seal drain hole in aftermarket oil pumps. As you can see in the pictures below, first is a 6-bolt ACL oil pump and the second is an OEM 6-bolt oil pump. The OEM pump clearly has an offset drain hole to keep from accidently clogging the hole with RTV but the ACL and Topline have it for n the oil pan of gasket area.
Has anyone had issues with getting RTV in this hole and what have you done make sure that this does not happen? I put a wire in a Topline pump back in the day but the angle is a bit different in the ACL so I'm not able to do that.
