Oil Pressure Gauge - 91 Talon Tsi AWD
temfate
227
May 9, 2004
Denver, Colorado
On my 91 Talon the oil pressure gauge shows no reading whatsoever, although I know there is oil pressure. I check down near the oil filter and found two wires hanging not attached to anything, and nothing to attach them to. I'm guessing this means the part broke of my Oil Pressure Sender... Is this correct? Does anyone have a picture of what this area should look like?
i had the same problem, there are three wires that come off that part of the harness, two for oil sending and one for your power steering.. the plastic covered plug on harness has a connection that looks like an old ford coil connection, that one goes on the oil sending unit that is facing down (larger bell shaped unit) then your other connection goes to the sender facing radiator.. if your harrness has been damaged, you can go to your local parts house and get a ford coil connector to reconect the bottom sender, the other just has a "eye" hook... or go to wreaking yard and get a new old chunk of harness and wire in... good luck
-The tin can looking object on the far right in this photo is the oil pressure sender unit.
BUCK said:
Good pic of another Air to Oil Cooler setup off a Stock 91 OFH in my Gallery.
Yep, that picture was perfect; got it hooked back up now... thanks...
    • george bromwell
    • pma1123
    • Sdcryan1
