oil pressur and fuel gauge not working after dash swap
htamotorsports
Dec 2, 2006
mansfield center, Connecticut
i swapped out my dash and now my gas gauge goes all the way to full and my oil pressure gauge stays at zero,and my antilock light is on, i made sure i plugged in the 3 dash harnesses, everything else works but those gauges.
I'm suprised you're car would even start. I sold my extra dash to a guy and after install it wouldn't start, put the old dash back in and it fired right up. We looked around and found out that they have different part #'s. Makes them not interchangable. Check the part #'s to see if they match, you might be having a problem with year to year interchangability. I forgot to mention that my extra dash was from a 91 with abs and we tried to put it in a 92 without abs.
    • The_Partout_Spot
    • The_Partout_Spot
  • For sale Garage clean out
    • 92GSXtacy
  • For sale 4G63 Griffin intercooler cores
    Griffin intercooler cores. Top to bottom flow. High cfm and heat transfer. 24x8x2.75 and...
