boost gauge and oil gauge not working
Are you talking about the stock gauges on your instrument cluster? If so, especially your boost gauge there not so accurate. But as for the oil gauge, does your oil light come on out all? Check your ofh and see if your oil sensor is plugged in still. The gas gauge could possibly be the float in your tank going bad or the connector that goes to it. To fix your boost gauge, definitely get an aftermarket one and tap into your fps. Good luck bud.
What is the ofh? My oil gauge is also not working. Not worried about the boost since I have an aftermarket one.
hey guys thanks for the response ! I have a aftermarket boost gauge already so im not to worried about the stock one working. oil light never has came on just gave it an oil change and I check it every once in a while and it seems good I also have a oil/fuel ratio gauge just not hooked up yet so im really not worried about the gauges just kinda bugs me how they just sit there LOL. I will probably just replace the float for the gas gauge also
