oil pan gasket difference?
talondsm24
102
Aug 28, 2009
Arvada, Colorado
im needing to replave my oil pan gasket so i was wondering, is it the same gasket for the 2g as the 1g as long as they are both for a 4g63? seems like there are only 2g gaskets on ebay, but theoretically they should be the same?
Hey Paul,
I've used different types of gaskets (cork and rubber) AND RTV and the god damn thing still leaks!!!
Your suggestion is to use gray RTV only? The problem I have is that the oil pan is not flat. The bolt holes are all bent upwards to the block. That means I need a new oil pan, right?
If so, where should I get one? I've looked at extremepsi and the pan is $200. Is there a place to get one cheaper?????
Thanks Paul,
Tom
STM has pans for like 100
Tnx for the info. Last question.... where can I get a new 7 bolt oil pan cheap? The best price i have so far is extremepsi at $200 plus $100 for shipping to Canada.
Is that US or CDN $? If it is US then you can get it from Chrysler for around the same price. $356 CDN. Might get it from Mitsu a little cheaper.
Yeah, I feel your pain, Tom. I battled leaking oil pans for a few weeks last year. I went through 4 oil pans in those few weeks before I finally got a good one. One of my leaky ones was exactly how you describe yours. Every one of the holes on the rail were bent upward and deformed. No matter what I did, it just wouldn't seal. I eventually found a guy that was selling one that had been purchased new and only used for about 1000 miles, so I could be sure I was getting one without any flaws.
From my experience, the rail on the pan must be flat and free of any deformation or it will leak. I tried to fix my bent ones, but nothing worked. A good replacement is the only fix that I came up with. I'd recommend just start searching the classifieds until you come across one that is in better shape than most. I paid $70 for the good one that I found (he said he paid $200 for it new), and I feel it was well worth it due to it being in like-new condition.
My frustrations:
At least you didn't spend $165 for a new OEM 7 bolt pan just to put 4 holes in it hours later.
I took mine back to a friend that works at Mitsubishi and told him it was defective. He swapped it out and wrote it up as an "unsealable" oil pan.
Mine is leaking pretty bad too. When I had it rebuilt it looks like a gasket and RTV was used. I'm gonna rip it off and make sure it's clean and straight before reinstalling with just Right Stuff.
