Oil Pan gasket
1G_FL_AWD
Apr 18, 2010
Tampa, Florida
saw a thread for a 2g awd but heres for the 1g...
Is it also true that on awd 1g's there is no oil pan gasket?? and if so what application is this intended for?
It says both turbo and non turbo...is that right?
Store Locator | NAPA Online
I was under the impression that 6 and 7 bolt oil pans were different and would potentially need diff gaskets...
Anyone have tips or heads ups for a first timer doing this gasket??? what will i need to do to get it off in the most time efficient way?
I used a cork gasket with a thin layer of rtv on both sides on my 7-bolt . Seems to work pretty good. In order to get the old gasket off just use a gasket scraper.
