oil pan for 4g64?
99eclipse420
250
Jul 7, 2011
irmo, South Carolina
Hey I have a 97 spyder and I am in need of an oil pan. The only issue is I can not find one so being that a 4g63 head will bolt up to a 4g64 block I was wondering if I could use an oil pan from a 6 bolt or a 7 bolt motor to fix the problem, or if anyone knows where I can find a new o.e.m oil pan for my spyder. Once again thanks for the advice and comments.
Dont quote me on this but when i researched turboing the 4g64 they said that you should switch to the 4g63 oil pan for the oil return for the turbo. So from what i read the 4g63 oil pan bolt right up but you would have to take care of the oil return hole/port but again i would double check this
