-10 return line for oil pan
68442
639
5
Oct 14, 2007
Des Moines, Iowa
Sick of the stock one leaking and stripped out a hole today on the pan. Does anyone sell a pan with a -10 welded in? Other idea I have is take a -10 fitting to someone to weld it into the pan and weld the stock bolt holes.
I dont know of anyone that sells pans pre welded. Maybe give STM a call as I am sure they can set you up with something. The new oil pans in stock. If that is out your price range give Graveyard a call as they may have used ones in stock and can probably weld on a -10 fitting as well.
If not just purchase a fitting and have it welded on locally.
